Home Forums Products Stompboxes H90 with Boss ES-8 Reply To: H90 with Boss ES-8
#168609
Enabling Dual Mode will automatically change the available lists you can use. By default, the User 1 list will have all of the Presets on Path 1. You can press the Routing button to change which path the presets are on.
If you press the Programs button and select the Pre-Post or Bass list, these Programs will have one Preset on either path.
