Home Forums Products Stompboxes Can’t play over loop Ultratap Reply To: Can’t play over loop Ultratap
#168666
joecozzi
Try setting your pedal to DSP Bypass. To access these Global Settings, apply power while holding ACTIVE Footswitch and triangle button on the top right. Once the lights are blinking, press the Active LED button (above the active footswitch) and make sure the third button on the preset ladder is lit for “DSP+FX.” Power cycle the pedal. Now try it.
