Home Forums Products Rackmount Several issues I’ve found along the way Reply To: Several issues I’ve found along the way
#168949
vpajerski
Ok. I tried it again and I can’t reproduce it either.
However, when I try to use a pedal in an algo, it doesn’t work.  Try algo 6640 and tell me what you see.  It acts like the expression pedal is an on/off switch.  On the physical unit, things are worse I try to disable the pedal for certain inputs and the UI is garbled. It writes UI elements on top of one another and doesn’t function correctly.  I can try a few more and see what happens. Also the on/off switch on the parameters page is non-responsive (in Emote).
