Home › Forums › Products › Stompboxes › Another H90 Routing Question › Reply To: Another H90 Routing Question
February 9, 2023 at 3:51 pm
#169007
Hi WrendorWC,
You have a really solid plan. Connecting the H90 using Dual mode in pre/post will give you the most flexibility with post cab effects, since you can have a program with two presets in the post path. You could even go one step further and put the H90’s pre path in the HX Stomp’s effect loop in case you ever wanted to use an Eventide algorithm before or after any of the Stomp’s processing. You’ll have to always keep the Stomp’s FX loop engaged on the Stomp though.
