Home Forums Products Stompboxes External Control Access to H90 Perform Mode 2 Please Reply To: External Control Access to H90 Perform Mode 2 Please
#169024
rograt
Yes that is correct. Apologies for throwing you off the trail. Access to those 6 modes is exactly what I want and as you say it will be different for every program.
The advantage of switching between pages on the unit is that the display tells you exactly what you are switching so if I could do this with my remote switch it would be a lot cleaner.
If I had a second bank of switches I would have to sacrifice the EXP pedal which is like my right arm. Unfortunately I’m now maxed out on control in’s on the ES8 or I could have put the EXP into the ES8 and relayed MIDI out.
So, yes if the remote switch could toggle banks rather than just go into Perform mode it would be better.
