Home Forums Products Stompboxes Rose expression pedal Reply To: Rose expression pedal
#169404
tsternfeld
A look at the specs for that pedal suggests it should work correctly (and isn’t now).  There are a few things to check before you assume anything’s broken:
– Check you are using a TRS cable (not a tip/sleeve instrument cable) and that all three connections work correctly.
– The expression pedal has polarity switches that change its internal circuit configurations.  Perhaps they are set incorrectly.
