Home Forums Products Rackmount New H9000 Public Beta Reply To: New H9000 Public Beta
#171790
This behavior depends on both the note mode and poly mode settings.
When using mono mode, only 1 MIDI note is received and is applied to both voices.
When using poly mode:
– Normal: Voices are assigned in a round robin fashion.
– Ordered: First note played is always Voice1. Then Voice2 and so on.
– Spread1: All notes play if any keys are pressed. Voice1 is the highest,
Voice2 is the next highest and so on. The note assignment happens every time you press a key.
If you just press one note, all voices play the same note.
– Spread2: Just like spread1 except that note assignment also happens when you lift up a key.
When you lift up from a chord, you’re left with all voices playing one note.
The best way to figure out how it works is to play around and you should get the hang of it.
