Home › Forums › Products › Stompboxes › H90 Midi Global Settings › Reply To: H90 Midi Global Settings
#173473
dknobler
    I work in a studio environment where I am often searching for and sculpting new sounds on the fly. I start with various presets but want to be able to make changes via MIDI CC quickly. In regards to the clocking, sometimes we are on a click track, sometimes not. There are times where I’d like all the pedals on my board to be in sync with each other and there are times where I want to individually tap out tempos / speeds per pedal. I have a set of CC messages that turn the MIDI clocks on and off for other time-based pedals.
    The routing I was thinking about switching between Series / Parallel and moving the placement of the inserts. Again, sometimes in the studio I want to be able to quickly audition sounds and the ability to have a quick MIDI command to do things like change the routing or flip the order of the two presets or inserts would be useful.
