Home Forums Products Stompboxes H90 and Disaster Area Micro.Clock External Tempo Reply To: H90 and Disaster Area Micro.Clock External Tempo
#174016
    That should work fine with the H90 using a standard TRS cable. The H90 should be used with momentary normally open switches.
    Do you just need an aux switch to control the H90’s clock via tap tempo? If so, then you could get a much simpler aux switch to accomplish this instead of the Micro.Clock.
