Home Forums Products Stompboxes H90 global gain/volume Reply To: H90 global gain/volume
#174179
honeybrew
    Yes, it’s true, there are some inconsistencies between programs and it may stem from the variety of sound designers that worked on H90. However, all Program/Presets can be easily adjusted to work with your setup. You just have to decide what method works best – adjusting Program output gain, preset gains or both, depending on the effects routing.
    I think would be best to level up all the presets by factory, so users don’t have to spend time on fixing this or risking equipment or hearing damage due to unexpected overloads.
