Home Forums Products Stompboxes Mixing Link on stage for personal monitoring Reply To: Mixing Link on stage for personal monitoring
#174349
Hi Thorsten,
Yes, this is possible and I would recommend your suggested use case. The headphone output level is independent of the DI out level, so this would allow you to adjust your headphone mix without changing the DI level.
