Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#175305
eturnian
    I really agree with @RomanCromov here. I too am using an amp sim pedal as an insert so that I can route weed whacker or phaser algos before the amp and modulation, delays and reverbs after the amp for more studio quality sounds. It works beautifully. I love the routing options. But I think there should be a global routing option that we can simply set up for the whole pedal. Then in each program we could have the option to chose between custom routing or just use the global setting. Kind of like the kill dry. The global routing should work even when the pedal is bypassed. Currently when using my amp sim as an insert, if I bypass the h90 I loose everything in the insert path, which means I no longer have my amp. It would be great if I could hit bypass and still be running through the insert. Thanks
