Home › Forums › Products › Stompboxes › H90 Wah Pedal without artifacts? › Reply To: H90 Wah Pedal without artifacts?
#175479
    That’s puzzling. Now I’m thinking a clogged MIDI pipeline, somehow.  That Morningstar is capable of sending massive amounts of data downstream, and well … it’s all through a serial transmission.
    A couple quick questions:
    • Do you have OMNI ON in the H90, or receiving on a single MIDI Channel?
    • How are you rigged up MIDI-wise?  Lots of daisy-chaining IN->THRU, any THRU boxes, maybe vintage MIDI boxes anywhere?
    • It’s difficult to diagnose MIDI issues remotely, but some idea of your entire rig might help.
    I also have an MC-6 Pro, but I’m using an S/A Reflex through it. I find it has a smoother sweep with the finer resolution. My EV-5s hook up directly to the H90s.
    One of the EV-5s is a little flaky for consistently getting a full range.  Let me try the more reliable one in your MIDI configuration, and see what I come up with.
    For comparison’s sake, try your EV-5 straight into the H90, and we’ll swap some notes later on.
