Home Forums Products Stompboxes H90 looper playback speed varies/jumps Reply To: H90 looper playback speed varies/jumps
#175901
Reddy_Kilowatt
    Another observation… the transport display on the 1-button looper has an issue. I have an 8 beat loop repeating. The transport counts through beats 1 through 7 correctly, but at beat 8 it displays beat 1 for 2 beats. So 1 2 3 4 5 6 7 1 1 2 3 4 5 6 7 1 1 2 3 4 5 6 7 1 1 and so forth. I think it’s remaining synched with the Beat Buddy clock for playback, but the display isn’t correct.
    Adding to this… it seems like the Loop Play-Length is getting confused.  For example, with an 8 beat Loop Length (recorded with Loop Max-Length at 8 beats and allowed to record all the way through and autoclose the loop), the Loop Play-Length will commonly change itself down to 7 beats.  This isn’t specific to 8 beat loops… I’ve seen it with 16, 32, etc.
