Home › Forums › Products › Stompboxes › H90 algorithms doesen’t detect stereo signal from stereo loop › Reply To: H90 algorithms doesen’t detect stereo signal from stereo loop
#176579
Robjob223
    Having my signal split pre-H90 (so as to use both inputs 1 and 2 on h90) does seem to fix everything.  The odd behavior seems to be the H90 changing its mind about whether the insert is stereo based on whether the effect following it is engaged or bypassed (in the case where the “raw input” into h90 is just input 1).
