Home › Forums › Products › Stompboxes › Eventide H90 – Filter via expression pedal › Reply To: Eventide H90 – Filter via expression pedal
December 12, 2023 at 9:20 am
#176682
You can accomplish lowpass/highpass using ModFilter: https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/algorithms/modulation.html#modfilter
There is built in modulation, but if you set Shape to Manual and map an expression pedal to the Manual Mod parameter, now you have a filter controlled via expression pedal.
You could also use the Dusk as an insert in the H90, and put your filter before/between/after any of the H90’s presets.
