Home Forums Products Stompboxes Help with H90 Blue tooth not working Reply To: Help with H90 Blue tooth not working
#176804
    Sorry you are still having issues but It’s not clear if you read the instructions I sent you. You need to use H90 Control to initiate the pairing process, you should not go to Settings > Bluetooth on your iPad unless you are forgetting the H90 from your iPad’s list of devices.
    If you are following the instructions from the manual and are still having issues, please contact support@eventide.com and we can help you further there.
