Home Forums Products Stompboxes Recommended expression pedals for H90 Reply To: Recommended expression pedals for H90
#176840
joecozzi
    As a straight expression pedal it is compatible with H90 but understand if you want to use the toe switch and the expression pedal at the same time each takes up its own port on the H90. The EXP inputs of the pedal can be configured for either an aux switch or expression, but not both. Also, this particular expression pedal requires a separate power supply for the LED functionality.
