Home › Forums › Products › Rackmount › latency across the FX chains › Reply To: latency across the FX chains
#176879
    Hey Colin,
    All of the latency information can be found here: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/setup/DAWLatencyCompensation.html
    The latency is dynamic for each FX Chain depending the algorithm routing. A simple way to keep the latency of the FX Chains fixed is by building your FX Chains from the bottom up. Once an algorithm is placed in the bottom slot, that will configure the FX Chain to use highest amount of latency (around 3.3 ms).
