Home Forums Products Stompboxes H90 tempo sync with timefactor, won’t match Reply To: H90 tempo sync with timefactor, won’t match
#177008
tsternfeld
    Do the tempos match in the sound?  Does the difference persist if you swap the order of H90 and TimeFactor?  When you see the difference, what tempo do you have the MIDI CLK generator set to generate?
    The H90 benefits from many improvements to the tracking of MIDI CLK, so it is possible that it is just providing you a more accurate reading.
