Home Forums Products Stompboxes Delay Glitches with MIDI PC changes Reply To: Delay Glitches with MIDI PC changes
#177066
njdelyster
    Do you mean only using a single delay algo? That would be a limited use case for what is considered to be a powerful effects processor. I had hoped to replace the Timeline with the H90 as it is by far the more substantive piece of kit … even with the TL you can turn off the morphing time-based pitch warbles.
    The H90 is on a unique midi channel and the drives are in different loops on the PBC so there are no PC conflicts. I could change the set-up on the PBC to minimise the PC messages but that wouldn’t solve the issue as I’d still want to change between delay algorithms and encounter the same issue.
    Does anyone know if the original Factor pedals have this quirk? I didn’t use delays heavily on the H9 but I don’t remember this behaviour there either (?).
