Home Forums Products Stompboxes Delay Glitches with MIDI PC changes Reply To: Delay Glitches with MIDI PC changes
#177068
I might be the last person to suggest using a single algo, for any kind of situation.  I was reacting to what I thought was implied, reading into the OP.  I use several MIDI controllers, but have only a passing familiarity with the RJM.  Perhaps Eventide can provide an alternative solution here.
I don’t recall whether or not the H9 had the same result with a reloaded PC message.  I still have 3 on a ‘board, so I can check on that later.  Obviously, using Programs / Presets with different delay times / parameter settings on certain algorithms will warble between PCs.  I don’t believe a PitchFactor test will be fruitful for this, as all of those delays are crossfaded.
