Home Forums Products Eurorack Modules Misha Sequencer options Reply To: Misha Sequencer options
#178230
If you have an external clock divider module, that would be a good way to accomplish changing the playmode every time the sequence is completed. Misha will send a trigger for every pulse, if you send that trigger output from Misha to the clock divider, then you will only have 1 pulse for every X amount of triggers depending on the clock divider settings. Then, send that back to one of Misha’s trigger inputs to change the play mode (or something else!).
