Home › Forums › Products › Stompboxes › H9 Max – Wet/Dry and expression pedal control inputvolume › Reply To: H9 Max – Wet/Dry and expression pedal control inputvolume
#178686
mariosr
    Hello Eventide Staff,
    thank you very much for your response.
    Controlling the Mix level does not work for me, because if I reduce the Mix level, the decaying ‘tail’ of the current effect will be mixed out as well.
    What I want to do is, to select an effect with a long decay, play a chord with input level at max, then to set the input level to zero for playing over the decaying tail of the effect, through the dry channel only.
    It is disappointing that it does not work and very strange, that it works for the output volume control. Controlling the output volume in the Wet/Dry setting, affects only the wet signal!
    In my opinion it would be more usable if it would work the opposite way. Input swell, to do what I actually wanted and output swell, to use it as a volume pedal.
    br
    Mario
