Home Forums Products Stompboxes H90 with Boss ES-8 Reply To: H90 with Boss ES-8
#179946
    Yes, all that is correct. On the H90, go to System > MIDI > PC Offset, and set this to 1. This will make your PC numbers line up. If the channels on both devices are set to 1, you should be all set. The H90 will load the Programs from the currently selected list.
    Let me know if this works.
