Home Forums Products Stompboxes h90 looper control delay Reply To: h90 looper control delay
#182588
I was.  Sorry if that was unclear.  I assume your MC8 features are the same as the MC6 Pro here.  My suggestion was to set the transmitting MC8 switch at maximum sensitivity.  Then use that as a diagnostic to determine if the small delay is on the MC8 controller end, or on the H90’s reception of that MIDI CC.
https://manuals.morningstar.io/mc-midi-controller/Looper-Mode-for-Zero-latency-Looper-Control.186155011.html
I guess it could also be caused by a lot of unrelated MIDI messages being transmitted ‘simultaneously’ (serially) by the same switch.  As the MC6 Pro can transmit up to 32, it’s worth mentioning as another possible cause.
