Home Forums Products Stompboxes How to connect H90 to Friedman IR-D and Zoom A3 Reply To: How to connect H90 to Friedman IR-D and Zoom A3
#183434
    Yes, you’ll want to use Dual Routing for this setup.
    If your guitar first goes to H90 preset A, and then to the IR-D, then your effect from preset A should always be present on the IR-D outputs. Have you tried this setup and are experiencing something else?
    The setup should be something like:
    Pickup 1 > H90 input 1 > H90 output 1> IR-D > amp and PA
    Pickup 2 > H90 input 3 > H90 output 3 > A3 and PA
