Home Forums Products Rackmount DB25 Pin Out Question Reply To: DB25 Pin Out Question
#183487
vanceg
<p style=”text-align: left;”>I apologize – I got distracted and should follow up on this a little later today.</p>
I’d be pretty concerned about the signal level and noise without providing amplification for those signals from the GK3 b.
The dual GK3 b setup, while innovative, seems somewhat donkey as well.  Have you considered using a pickup system designed  for the number of strings your instrument has? Have you considered a Cycfi rig, for example?
if getting another pickup system is out of the question, then I’d recommend trying the single gk3b without any amplification/no 7v sent to the gk3-b and see if you get anywhere close to the level signal that you want out of this thing.
I’d strongly recommend taking a look at a Cycfi rig.  If that’s just not in the cards, you might want to try building or quitting a breakout box or cable that can provide the 7v for your gk3b.  It’s not all that tough to insert that 7v. And cables by Bill Bax and others can provide you with a prebuilt option.
