Home › Forums › Products › Stompboxes › H90 AND FOOTSWITCH EXTERNAL › Reply To: H90 AND FOOTSWITCH EXTERNAL
July 16, 2024 at 10:34 am
#183778
Thank you. The issue is both Tap Tempo and Load are assigned to Aux Switch 1. You will need to assign these functions to different Aux Switches to avoid the problem you are experiencing.
If you do not need your switch to load a Program, you can turn the “Load” mapping to off.
Otherwise, you should map that to another footswitch.
Let me know if you have any other questions.
