Home Forums Products Stompboxes Change Presets (not Programs) via a foot switch? Reply To: Change Presets (not Programs) via a foot switch?
#184057
    There is no option to change individual presets within a Program remotely and there is no global routing option so that the pedal is always in pre/post routing in dual mode.
    Your best option would be choosing a new list as a starting point for the programs you want to create, manually change the routing to pre/post for however many Programs you need on this list, and saving them with that routing configuration. Then when you load a new Program from this list, it will have the correct routing.
    There are some Programs in the “Pre-Post” list that have this routing configuration by default. You can also use the favorites tags for your Programs that are saved with the routing you like.
