Home Forums Products Stompboxes H90 with OX box Reply To: H90 with OX box
#184058
    The Ox Box should not be used as an insert as it needs to connect directly to your amp.
    I would suggest using Dual Mode on the H90 and trying this:
    Guitar > Compressor / Drive pedals > H90 Input 1
    H90 Output 1 > Guitar amp input (amp connected to Ox Box)
    Ox Box Outputs 1-2 > H90 Inputs 3-4
    H90 Output 3-4 > Stereo monitors
    This setup will allow you to have different effects before/after the preamp stage. Press the routing button to choose which preset is on which path: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/edit-modes/routing.html#dual-routing
    Let me know if you have any questions.
