Home › Forums › Products › Stompboxes › Dedicated FREEZE Algorithm – H90 › Reply To: Dedicated FREEZE Algorithm – H90
July 30, 2024 at 9:11 pm
#184081
amc8
Agreed, my superego plus is the only pedal the h90 hasn’t replaced.
Having a freeze with added pitch shift with overlap/portamento would be amazing.
I’ve found it hard to get smooth pad sounds on the poly synth plugin because it always cuts off the previous chord as you play the new one.
Can work around with the freeze param and/or delays and verb tails but having an automatic freeze envelope would be killer.
