Home Forums Products Rackmount PCMCIA card with flash card works for firmware but not presets Reply To: PCMCIA card with flash card works for firmware but not presets
#185968
chris daniels
I assume you mean you are using a CF card with a PCMCIA adapter? My initial intuition The H8000 is very picky about the formats of the CF card; we recommend only using the format that the card is programmed with out of the box (FAT16, with certain flags set), but most OS’s don’t support FAT16 formatting easily. I would suggest trying a tool like gparted (https://gparted.org/ ) to format the drive as FAT16. Note: that tool will just as happily format your hard drive, so exercise care.
Thanks, after reformat a second time it does give the option to select the card but says not enough memory and reads   -12xxxxx on available memory so not liking this card.
Regards  Chris
