Home Forums Products Stompboxes New Beta – Looper function Reply To: New Beta – Looper function
#185971
danperfect
Further to this, I’m getting problems with assigning Performance Parameter map values to the looper functions. I am finding that using the H90 Control, the parameter map does not persist after save. ie – I assign RECORD on switch A to MIDI cc 10 and save. I switch to another patch, and back to the edited one and the control Source is once again unassigned for the parameter I just saved. Doing this on the unit directly appears to persist, and this all  worked fine before updating on H90 Control. However, if I edit the control source & cc value on the hardware unit, the correct value is not displayed on H90 Control – in this case I map MIDI cc 10 to RECORD, but on H90 Control it displays as cc 0.
Another strange behaviour I’m getting is using the P/A/B LED buttons – pressing down A gives me the performance parameter mapping page – in Looper its 1buttonloop/record/play/stop/erase/undo – if I then press P, I get Act/byp/Hotswitch/tap, but then if I press A again I don’t get the looper functions (even though the display shows ‘A Performance Parameter Mapping’), I get the same as if I had pressed P. I have to press PERFORM again to go back, and then press A again to access the looper functions once again
I think I can manage using the hardware to program the PP values without having to revert for the time being..
