Home › Forums › Products › Stompboxes › balanced TRS I/O to H90s unbalanced TS I/O › Reply To: balanced TRS I/O to H90s unbalanced TS I/O
November 8, 2024 at 10:04 am
#186090
What’s the device? If it has one phase connected to ground, it’s not actually a balanced IO. Either way, I’d suspect that the grounded phase is the ring, which would be exactly the same situation as the H90 (and thus indistinguishable from using unbalanced I/O).
