Home Forums Products Stompboxes balanced TRS I/O to H90s unbalanced TS I/O Reply To: balanced TRS I/O to H90s unbalanced TS I/O
#186095
tsternfeld
I should add, it does look like they have a low interpretation of “pro” level for their inputs, so I would see if you get enough signal with your H90 outputs in instrument level rather than line level (the H90 will comfortably exceed their recommended maximum input level, if pushed).
