Home › Forums › Products › Stompboxes › External control of Quickknob parameters › Reply To: External control of Quickknob parameters
November 11, 2024 at 8:43 pm
#186159
tiresias
Hi ~ I’ve been trying to achieve the same results with midi. I’m not having much luck with mapping different values of the same parameter directly to different cc numbers. I can’t tell from the video if this is actually possible? Or do i have to do the Hotswitch mapping and then map the hotswitches to controller numbers?
