Home › Forums › Products › Stompboxes › External control of Quickknob parameters › Reply To: External control of Quickknob parameters
November 12, 2024 at 9:10 am
#186163
Can you be more specific with what the issue you are having is? For example, map CC 1 to preset A mix, and send different CC values to adjust the preset A mix parameter. What have you tried and what is not working?
You can map your MIDI CCs directly to the parameters, or you can map your MIDI CCs to a Hot Switch.
