Home Forums Products Rackmount Eclipse Newbie General Questions Reply To: Eclipse Newbie General Questions
#186322
pdxken
It’s been a while since I had my eclipse so my memory may be a bit hazy but the eclipse will sync to MIDI clock, I used a MIDI – usb dongle to get from mac to eclipse, then you’ll need to change a setting on the eclipse IIRC.
I had mine connected to my audio interface via coaxial SPDIF and used it as a send FX, I felt that was the best option as it skips a couple AD conversions. Then I just set the global mix on the eclipse to 100% and adjusted the return in my DAW to taste.
FWIW Wise is safe, I’ve been using it almost three years (US > UA transfers) without any problems.
Enjoy the eclipse, it’s amazing for being 20+ years old!
