Home Forums Products Stompboxes MIDI Program Change reactivity Reply To: MIDI Program Change reactivity
#186409
Not to discount the MIDI question (it’s come up before).  It’d be helpful to Eventide if you specified which MIDI controller you’re using.  And maybe even the current Tempo (if applicable) for delta time calculations.
But what struck me here was an easy alternative:  You require a Program load – via PC message – immediately followed by a HotSwitch configuration.  Can’t you just re-save the Program with HS(x) = ON?  No delay; it’s now part of the initial Program load operation.
