Home › Forums › Products › Stompboxes › Setting up H90 with Quad Cortex › Reply To: Setting up H90 with Quad Cortex
December 5, 2024 at 6:40 pm
#186733
DustyF92
Ok so I’ve got my h90 and I’ve been trying to get it to work the way I was hoping for over 2 hours at this point…
Essentially with the Quad I was hoping to use both FX loops, connected to ins 1/2 and outs 1/2 and then use the insert on the H90 (in/out 3) for my drive pedal… I was hoping to be able to split the signal coming out of the H90 into outs 1 and two separately (dual mode) but then I can’t add my insert….
My hope is to run my drive pedal and path A to FX loop 1 and then Path B into FX loop 2. Is that doable?
