Home › Forums › Products › Stompboxes › TimeFactor and MIDI pass-through › Reply To: TimeFactor and MIDI pass-through
        December 12, 2024 at 9:59 am
        #186845
There are a few things you’ll need to do to make all of this work.
- On the MIDI controller, confirm that you are sending different CC messages on different MIDI channels for the various footswitches.
- On the TimeFactor, confirm that you have MIDI receive set to channel 1, MIDI output set to THRU, and you also need to map various parameter to MIDI CCs. I would suggest mapping “Active/Bypass Toggle” to something like CC1. With these settings, you will need to map the Morningstar to send MIDI CC1 on channel 1 for the TimeFactor to receive the active/bypass command.
- On the Strymon, confirm that MIDI receive channel is 3, and that you are sending the correct CCs to adjust settings. You’ll need to check the manual to confirm these settings.
I would start by connecting the MIDI controller directly to each pedal (no MIDI thru) to confirm that you are sending the correct MIDI messages. Once that is all good, try using the MIDI thru on the TimeFactor.
