Home › Forums › Products › Stompboxes › H9 Use case – Can it do this… › Reply To: H9 Use case – Can it do this…
December 12, 2024 at 8:34 pm
#186868
Adam DAgosto
Hi again, now you have me thinking about the H90 more. So let’s expand on this….
Is it possible then to connect the H90 to the tube amps via 4CM or so other way to enable the tube amps to have pre-H90 effects AND post-H90 effects in the loop AND ALSO be able to connect to the HX Somp?
I think there are enough ins and outs. Can that work? If so, that’s having your cake and getting to eat it!!
