Home Forums Products Rackmount H3000 system exclusive format Reply To: H3000 system exclusive format
#186876
tmoravan
The screenshots look excellent.  Great work there.  Thanks for confirming some of the unusual behaviors.  There’s also the weirdness of some parameters looking like integer values but still allow you to type in a fractional value.  I haven’t tested to see if that fractional part is saved and returned or not.
My going in position will be to set the range to whatever can be saved and recalled no matter what the front panel allows you to do.
I did make my H3000 editor for the Electra One hardware public and did implement all the algorithms.  So if you have questions about 118 – 123, just ask; always happy to help.  As you know, the Electra One gives you a lot of flexibility, but you are still constrained by the device as far as how much info can be presented at once and the very minimal graphics capability.  My goal always was to get the full complement of parameters implemented correctly then go about trying to make each algorithm more easily presented and understood by shifting things around, adding some graphics, etc.
Note that I’ve been tweaking John’s original spreadsheet with updates for some ranges and a couple offset corrections.  The one I remember that is important is Algorithm 104, the Left Feedback parameter actually lives at offset 92, not 35.
