Home › Forums › Products › Stompboxes › Can’t Get Fully “Wet” Micropitched Signal › Reply To: Can’t Get Fully “Wet” Micropitched Signal
#187053
hoi_polloi
    Thanks for the guidance, but one more clarifying question before I try troubleshooting it again this evening.
    In your first response, you mention that the dry tone never goes away unless the pedal is set to Kill Dry. In the last response, however, you mention that with the Mix knob turned fully clockwise there is no dry signal even though the pedal in the video is not set to Kill Dry.
    Apologies in advance if I’m misinterpreting you.
