Home › Forums › Products › Stompboxes › Can’t Get Fully “Wet” Micropitched Signal › Reply To: Can’t Get Fully “Wet” Micropitched Signal
#187054
joecozzi
    In your first response, you mention that the dry tone never goes away unless the pedal is set to Kill Dry. In the last response, however, you mention that with the Mix knob turned fully clockwise there is no dry signal even though the pedal in the video is not set to Kill Dry. Apologies in advance if I’m misinterpreting you.
    When the pedal’s Mix knob is set fully CW, there is no dry signal present. However, if both Pitches are set to zero, that means they are generating a note that is unison to the original pitch, a copy if you will. This means the fully wet signal has the same pitch as the dry signal.
