Home › Forums › Products › Stompboxes › Input/Output 3 and 4 › Reply To: Input/Output 3 and 4
Hi, yes, thanks, another another possibly dumb question. When using CC numbers with a midi controller (MC6 Pro) and an expression pedal, are they programme specific? For instance if I’m using CC numbers 1,2 and 3 to control various parameters simultaneously on a particular programme can those numbers then be used again on a subsequent programme? The reason I’m asking is because I remember reading somewhere in the manual that it’s always preferable to use different CC numbers for different controller events. When i first read it I thought that’s a lot of controller numbers to keep track of if your using sixty programmes. But logically I guess there is no reason why a controller number would cause any action outside of the selected programme. Just checking.
