Home › Forums › Products › Stompboxes › Tap switch not working H90 › Reply To: Tap switch not working H90
December 26, 2024 at 8:53 am
#187197
![](https://cdn.eventideaudio.com/uploads/2023/01/brock_avatar-80x80.png)
It sounds like you’ve set up the proper external connection. Maybe it’s the final assignment part that’s missing?
That section (and the one below it) might get you there. I guess it’s possible that the ‘presets’ / Programs you’re targeting on your List aren’t set Tempo = ON. It can get a little confusing at first try, as you can control at Program or Preset level – with or without Tempo ON – depending on which Performance Parameter you are binding the Aux Switch to.
