Home Forums Products Rackmount FX Chains randomly work and then don’t as Logic plug-in Reply To: FX Chains randomly work and then don’t as Logic plug-in
#187318
amop
Thank you for the recommendation.  Disappointing to hear this is a longstanding issue.  I was hoping it was operator error.  I’m a bit too invested in Logic to make a DAW switch, if that’s the root cause.
Did a quick try of your suggestion by inserting the osc utility before the I/O and emote on my AUX channel.  No luck yet but will keep at it.
PS – hope you don’t mind a brief aside, but appreciated the opportunity to see you perform with TG in Los Angeles in 1981.
