Home › Forums › Products › Rackmount › H9K MIDI Feedback › Reply To: H9K MIDI Feedback
January 2, 2025 at 2:59 pm
#187364
That is the only setting to enable for MIDI Feedback to work.
In the MIDI Monitor app, make sure that the H9000 USB audio device is selected as a source.
Then, map an algorithm parameter such as “Mix” to a CC, such as CC1. When you adjust that parameter in Emote, you should see the H9000 output CC1 from the USB B port on the MIDI Monitor.
Note that Functions currently do no work with MIDI feedback, but any other parameter should work.
